Thread: fan again
Created on: 06/10/09 05:34 AM
lytnin
lytnin's Gravatar
fan again
06/10/09 5:34 AM
Bought a fan off ebay last night so gonna attemp to do the dual fan set up on the 14.
Will let you know how bad I screw it up.
Later == Bobby
jessejames4
jessejames4's Gravatar
Fairfield County, Connecticut
RE: fan again
06/10/09 8:11 AM
I saw that fan! I almost bought it!. I'm wondering if I just use the water wetter and wrap the pipes will I bring down the temp down?
Jesse 06 zx14 stolen back in 2019 97 zx11
BadinBlack
BadinBlack's Gravatar
RE: fan again
06/10/09 6:17 PM
I just picked up a second fan kit....my bikes never reall had any heat issues, but I figured with a turbo going on why not? I'll let you guys know what effect it has when I get it on
Paladin
Paladin's Gravatar
Cedar Rapids Iowa USA
RE: fan again
06/12/09 5:09 PM
I thought about it for the first 5000 miles, but now at 18000 miles I never even notice it running hot - 3 bars normaly, when stuck in traffic jams once in a while I see 4 bars - I quit worrying about it, just tight tolerances, should last a while.
Sharkey
Sharkey's Gravatar
Grass Valley, CA
RE: fan again
06/12/09 8:01 PM
I get a lot of heat on my right shin at stops or moving slow. I wondered if the second fan (which would go on the right side) would help with that?
Removed GPS.
BadinBlack
RE: fan again
06/12/09 8:13 PM
I'll let you know Sharkey
RE: fan again
06/13/09 12:11 AM
I am open air is no change in dash bar readings. I match, Paladin. I match leg warmth is same direction out is hit the hot air hits you first, being right behind it. Soooooooooooooooooooooooooooo...
WATT does that tell you about a fan and then second guess the engineering, sitting on a heat sink anyway.
Sharkey
Sharkey's Gravatar
Grass Valley, CA
RE: fan again
06/13/09 5:54 PM
How about putting the fan in reverse at stoplights?
Removed GPS.
